× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Password problems
AussieAngst
Follower
Password problems
Hi all,
Last night I changed my modem and tried to get my Netgear range extender to sync with my new router.
Did the process as shown in instructions. Reset Netgear extender, got it to pair with the new modem with "EXT" at the end of the device name but it wont accept the new password.
The password worked when I synced my mobile devices, but my range extender keeps telling me it is the wrong password. it should accept the password of my new modem
 as it did when I first bought it.
Grateful for any guru guidance, can't watch Netflix until I get my Netgear extender up and running again!!!!
Cheers
AussieAngst
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Password problems
Hello AussieAngst
While connected to the extender you can go to www.mywifiext.net login with admin/password then go to the wifi settings and try and change the password if that does not work you will have to reset the extender again by holding the reset button for 10 seconds and try the setup agian.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2534 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
