×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Password reset
Reinecke2-0
Follower
Password reset
My wife and I recently moved across town and I can't remember what our old password was to activate the range extender at our new home.
Has anyone else had a prpblem with re-setting their range extender after moving? If so, how did you overcome that password issue?
Thanks in advance.
Model: EX2700|N300 WiFi Range Extender
Message 1 of 2
Guru
Re: Password reset
You can reset it back to the original factory settings using the procedure on page 35 here: http://www.downloads.netgear.com/files/GDC/EX2700/EX2700_UM_EN.pdf
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 440 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
