- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Password
- Mark as New
- Bookmark
- Subscribe
- Permalink
Password
Where can I find my password? Can't remember what I used. Is it in accounts anywhere?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Password
which password?
the wifi password or the password to log into the device?
If you dont' know the wireless password, you can hardwire into the device and log into it. Then you can see the wireless info in the settings section.
if its the access to the device, and you don't know the recovery password info, then you'd need to reset it back to factory to get into it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Password
The password for the extender. I thought I used the same password for the WiFi for the extender because it says to use it in the set up instructions.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
