- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port forwarding for CCTV
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a CCTV unit plugged into my EX700 Nightwawk Extender by a LAN cable
My extender is connected to my Virginmedia Superhub 2 via wifi. I can use both the 2G & 5G around the house without problems on both the router & extender.
I can view my CCTV when on my WIFI at home without problem.
Problem starts when I try and use 3G/4G or an external WIFI the video stops after about a second of use.
I have tried to set the port forwarding on the Superhub and set the port as 3000 on 192.168.0.27 (the nighthawks ip)
This makes no difference.
Is there a facility to do port forwarding on the EX700 or am I doing this all wrong.
Please keep answers as basic as possible, I have very little knowledge of how networks work.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port forwarding for CCTV
When it comes to port forwarding, range extenders are invisible, so you do not need to forward to the EX7000. Change the port forwarding rule to forward to the IP address of the CCTV unit instead of the EX7000.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for getting back so promptly. How do I find the IP address of the CCTV unit. On its menu it states the ip as 192.168.0.27 which is the same as what the Virginmedia Superhub router displays as being the 5gz Nighthawk. Though there are 2 other ip addresses for the nighthawk.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the CCTV unit's own menu says its IP address is 192.168.0.27, then it's probably correct.
Have you tried turning off the EX7000 in order to rule out its involvement?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the advice, much appreciated. I can't take the extender out of the equation because the CCTV is too far away from the Virgin hub.
Having "googled" the problem it seems many people are having the same problem with port forwarding. I'll carry on reading and tinkering and if I find a solution I'll put it up on the forum.
I've opened port 3000 but when you scan it still says it's closed. Tried loads of "fixes" that I have read and none seem to work.
