Donnie57's avatar
Donnie57
Powerline 1000
Can you connect a Netgear Powerline 1000 to a Netgear ProSafe Gigabit Switch instead of your router?  My ports on my router are completely full...
  • plemans's avatar
    yes you can go Router-->switch-->powerline-->powerline.  I've done it before and it works great.
    • Donnie57's avatar
      Donnie57
      Thank you for your response!  Does the Switch with the Powerline 1000 have to be in close proximity of the Router?  My router is in a bedroom closet and the switch is across the house plugged into an ethernet port in my office.
      • plemans's avatar
        the powerline just needs ethernet access to the router/switch. Doesn't matter if its going through a switch to get there. I've even ran
        router-->switch-->switch-->powerline-->powerline-->switch.  It ran fine.
