Reply
Problems on some websites with my Netgear EAX20
Nenjiw
Follower
Hello,
I recently got a Netgear EAX20 in order to extend my wifi in the whole house. Problem is that I’ve encountered some difficulties accessing internet with some devices. For exemple some days it will work perfectly on my phone, and not on my smart tv. But next day my smart tv will be fine and my phone will start having troubles loading apps.
I don’t understand as I did all the setup correctly and all my lights are showing that it is working as it should be. Anyone else has had the same problems ?
Message 1 of 3
Guru
Re: Problems on some websites with my Netgear EAX20
What router is it connected to?
did you set it up using wps or the installation assistant?
what error do you get?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
Guru
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
@Nenjiw wrote:
Hello,
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK853 (Router Mode) | and R9000 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, R9000, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 307 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
