× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Proper function of LAN ports on EX7000 Range Extender in AP mode
jbrze
Follower
It remains unclear if the LAN ports on an EX7000 Range Extender will function in Access Point mode due to the statement on page 19: Note: In access point mode, you can connect your computer or WiFi device to the extender only using a WiFi connection. Some users claim this feature works and some users claim is does not. If the note on page 19 of the manual is incorrect why hasn’t this been corrected?
In a previous thread on 10/10/16 DarrenM wrote, “I just tested on my ex7000 you can use the ethernet while in ap mode I will have this updated.” If that is the case then why does this error remain in the downloadable user manual? This conflict of information is preventing me from purchasing an EX7000. This needs proper clarification.
Model: EX7000|AC1900 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Proper function of LAN ports on EX7000 Range Extender in AP mode
Yes you are able to use the ethernet ports in AP mode.
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 467 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
