- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6220 access point vs WAC104
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bonjour,
Je m'interroge sur la difference de fonctionnalité entre le R6220 en mode access point et le WAC104.
J'imagine que les 2 proposeront la même fonctionnalité et pourtant ils ne sont pas au même prix du tout.
Quelqu'un peut-il explique s'il y a une difference?
Merci pour votre aide.
Hello,
I wonder about the differences between the R6220 in access point qnd the WAC104.
I bet both will propose the same functionnalitie. However, they are not at the same price at all.
Does anyone can say if there is any difference?
Thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6220 access point vs WAC104
@Sylvain31 wrote:
Bonjour,
Hello,
It mainly comes down to business class versus consumer class.
R6220 is a consumer grade device so it has shorter warranty/support, supports fewer clients, a wan port for connection to a modem if needed.
Versus the WAC104 supports more clients, longer warranty and support with the option to upgrade for up to 5 years support. Usually the business class has more stringent power and environmental variables as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you very much for this information.
I was scratching my head trying to understand which model to choose.
For my home, then I will use the R6220 as it provides a better flexibility in case I change the overall configuration of my network.
