- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6250
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6250
Are you trying to connect the extender to the R6250?
You can do that. Its performance will be garbage, but you can do it.
It'll be garbage because single/dual band extender cut throughput in half.
This happens because they have to use the same wireless chip to go to router---->extender and then extender----->devices.
And they can't do both at once. So this reduces speeds in half.
And if you're already starting from the R6250 that isn't fast, it cuts an already slow speed in half.
Its going to make that extender sloooooowwwwww.......
and not at the fault of netgear but because its a bad setup.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
