Orbi WiFi 7 RBE973
Reply
R7000 Extending RAX43 Network?
freako13
Follower
Good afternoon, I have an RAX43 router set in standard Wireless mode. The unfortunate part is the signal doesn't reach the back yard. Is it possible to use my older R7000 to extend the wireless network provided by the RAX43? The two routers would be on two different floors, so connecting them directly via Ethernet is not possible, unfortunately.
Message 1 of 4
Guru
Re: R7000 Extending RAX43 Network?
If there is a repeater mode on the R7000 it maybe possible. If not, then no. Bridge mode is only for a client mode.
Would be better to get in to a EAX## something for wifi extending.
Message 2 of 4
Guru
The r7000 did have a repeater/extender mode. I think it might have been removed in one of the versions of firmware so you might check on if your firmware version has it or not. If not, you can try downgrading to an older (might be quite a bit older) version of firmware or check into 3rd party firmware like openwrt/ddwrt that do include those modes.
Message 3 of 4
A workaround here could be to connect the R7000 to the router using Powerline Ethernet. That turns the mains circuit into an ethernet network.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 475 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
