× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
R7300DST
kevpow
Initiate
R7300DST
Want to upgrade to at least WiFi 6 router. 1 bedroom apartment 875 sq feet. Suggestions?
Message 1 of 5
Guru
Re: R7300DST
What speeds do you pay for? The R7300dst is a pretty cable router and should cover that size apartment without any issues. Is it having issues? or you just wanting an upgrade?
Are you wanting to go to wifi 7? Or get one with 6ghz support?
Details are key on what you'd like and what you use it for.
Message 2 of 5
kevpow
Initiate
Re: R7300DST
I just moved from a Spectrum Business 600x20 to a Spectrum Consumer 1g x 1g. The upload is currently limited in my building so it’s probably 300mb. The router is over 7 years old so looking to upgrade. Only issue is the speed drop after handoff from Spectrum Modem to WiFi speeds from Nighthawk. A hardwired connection from Nighthawk is better but not near the 1g. Use cases, stream all entertainment, music (Sonos via Apple Music), DIRECTV stream and other streaming platforms thru AppleTV. Work from home as IT Director. Video meetings on MS Teams, Zoom, etc. Meetings were lagging after new Spectrum installation. But can’t pinpoint the nighthawk as issue but ready to upgrade. Appreciate the response !!
Message 3 of 5
Guru
Re: R7300DST
the new RS line of routers is the next generation wifi 7 devices.
If you're looking for dual band, I'd go RS200
If you want the 6ghz band, the triband RS600/RS700 are pretty darned good.
I've got an RS600 and its blazing fast.
there's a nice spreadsheet from dongknows about the specs for all 3 devices.
https://dongknows.com/netgear-unveils-three-new-nighthawk-wi-fi-7-routers/
I'd go with the rs600 over the rs700 because the extra $200 for the rs700 isn't that worth it.
I'd look at the wifi 7 generation if you're wanting 6ghz. The RAXE500/RAXE300 weren't bad but it didn't integrate the 6ghz into its smart connect (single ssid/name).
Message 4 of 5
Guru
Re: R7300DST
If you just want to try AX, there's a renewed RAX70 on amazon for $140 and its a triband (not 6ghz) AX6600 device. Fairly solid device
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 568 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
