Orbi WiFi 7 RBE973
Reply
RAX40 with EAX20 no internet
wifidoesntwork
Once my EAX20 router is connected to the RAX40 router, I can connect to the wifi signal but have no internet.  The extender seems to block the internet.  Netgear has replaced both the router and extender in the past 3 weeks and still no difference.  If I plug into the router the internet works fine, but cannot get a wifi connection unless the extender is disconnected and the router is rebooted.  Please help because Technical support has not been able to assist.  All firmware is up to date according to the Nighthawk app.
Message 1 of 4
wifidoesntwork
Re: RAX40 with EAX20 no internet
On the phone with support and placed on hold.  Then when they came back they disconnected the call without saying anything.  Netgear's support is awlful.
Message 2 of 4
Guru
What modem/gateway is the router connected to?
The router works fine if the extender isn't connected?
Message 3 of 4
wifidoesntwork
Yes the router worked fine without the extended plugged in.  Tech support finally solved the issue after 2.5 hours on the phone.  The firmware had to be downgraded.  Netgear needs to get this firmware issue resolved.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 807 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
