× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX48 Nighthawk AX6 6
xjgonzalez98
Follower
Router is working  for internet and Fire Stick but not with my ATT UVerse. The TV works for about 10 seconds and then freezes up and then disconnects. What do I adjust and how?
Message 1 of 2
Guru
Re: RAX48 Nighthawk AX6 6
att is notorious for giving using gateways with routers built in.
When adding another router to the mix, it can put  you in a double nat and cause issues.
https://kb.netgear.com/30186/What-is-Double-NAT
Especially with att.
What att  gateway do you have?
some have needed to put the netgear in AP mode so it ensures all the att services still work properly.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode-after-setting-it-up
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 332 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
