×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RN3000RPv3 extender reset
Jrowell123
Follower
I had to change my main network ID to which ny extender was tied,
For example: Change ABC123 to ABC222 while my extender's ID was ABC123_EXT
I need to now change my Extender's ID to tie it to my new network ID.
I can't access the extender network to do so.
Any suggestions appreciated.
Message 1 of 2
Guru
Re: RN3000RPv3 extender reset
You can factory reset the extender and then follow the install guide.
to factory reset push and hold the reset button for 7-15 seconds while the device is powered on.
then you should be able to follow that standard install guide.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 154 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
