× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Range Etender
theoldfeller
Range Etender
I have a home system running off a BT Smart Hub. I have extended the signal to our garage using a poweline system composed of a BT miniconnector connected to the Smart Hub  and a BT minihub in the garage. This is the system that BT recommended.
The signal in the house is good but the extended signal to the garage is patchy. The garage is 30 metres from the hub and there is no clear line of sight. Which NetGear product should I buy to improve the signal to the garage?
Thanks
Message 1 of 4
Guru
Re: Range Etender
You're currently running powerline out there?
That's a bit of distances and powerline is sensitive to interference.
Options that I'd consider?
1. run an ethernet cable. sometimes burying a cable isn't unreasonable because the cable is fairly cheap for underground rated.
2. Use a point to point system like netgear airbridge. there's cheaper versions from other companies.
3. If you've got coax ran out there, you can try a moca adapter (ethernet over coax)
Message 2 of 4
theoldfeller
Re: Range Etender
Thanks. There are trees between the 2 buildings. Would a PTP system like Netgear airbridge cope with that?
Message 3 of 4
Guru
Re: Range Etender
Tough to say.
They do attenuate the signal. And the more there is, the more that is blocked.
I've never used one so can't attest to how well they penetrate foliage.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2930 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
