Adina
Mar 12, 2019Follower
Range Extender AC1200 EX6200
Hi
I just bought the NETGEAR AC1200 WIFI RANGE EXTENDER
MODEL EX 6200v2
I activated it for the most part but the 5 GHz Link Rate is not lighting up - only the 2.4 GHz Link is
There are 2 houses on the same lot
1 has 2.4 internet
and another has 5
I have the Extender in the back house with the 2.4 internet speed - and I'm tryying to extend my WiFI range to the back yard in order to activate a pool app to work
Does anybody know ? SHOULD I PLACE THE RANGE EXTENDER IN THE FRONT HOUSE WITH THE BETTER INTERNET?
1 Reply
- Christian_RNETGEAR Employee Retired
Hello Adina,
If you recently purchased the device, we recommend contacting support for assistance using the provided link : https://www.netgear.com/support/default.aspx
~Christian
