julie72
Sep 01, 2015Follower
Range extender to detached garage
I have my netgear router in the house. We have a detached garage on different electrical circuit. Will a repeater work on a separate electrical circuit or does it need to be on the same electrical network as the router?
- nhannNETGEAR Employee Retired
Yes, the NETGEAR WiFi Range Extenders do not need to be on the same electrical circuit.
http://www.netgear.com/home/products/networking/wifi-range-extenders/However, the NETGEAR powerline do require that it be connected to the same electrical circuit.
- millertimeisnowAspirantMy suggestion. Buy something other than netgear. Their warranty and support is horrible. Check out linksys. I had a netgear extender for less than two months that broke. And they will do nothing about it.
