× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Rax120 often offline
smcorea
Follower
The router goes off line many tiles per day.
I often restart the router again.
The firmware is 1.0.1.136
Fancy router drives me crazy.
Also I contacted Internet provider, they said the line is working.
Which one is right?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Guru
Re: Rax120 often offline
Might be better to post in the AX routers section and not extender section.
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Do you "reset" the router or "reboot" it?
Resetting is a factory reset and reinstall. Its many times beneficial when firmwares changed. Have you actually tried a full factory reset?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 240 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
