- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Reconnect ex3700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reconnect ex3700
We just brought the extender earlier this month and it's been working fine. Today after my landlord reset the thermostat, the extender disconnected and now we can't get it to reconnect. I've reset it. Forgot the wifi on my iPad and reconnected. Went to the site from the booklet, but on the site it says those instructions aren't for my model. Even when I try the links, nothing loads up. All lights are green. Home network working fine. Extender just won't connect for some reason. Can anyone help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Reconnect ex3700
Have you tried factory resetting the extender, then connecting a pc/laptop to it via ethernet, and going through setup that route? If you do, disable the wifi on the pc/laptop you use so it doesn't default back to the wifi during setup.
What firmware is on the extender?
What router are you connecting it to?
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
