Reply
Reduced Speed from N300 Extender
Tarka
Tutor
On my Windows 10 laptop I am receiving Wifi 21MB from my router. I extended the signal with a N300 WN3000RP V3 unit.   However, when connecting my laptop to the extended signal, my Wifi speed then drops down to 11MB. The N300 signal is strong so there is no attenuation due to distance from main router but why has the speed been reduced by 50%.
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 3
Accepted Solutions
Tarka
Tutor
Re: Reduced Speed from N300 Extender
Thanks for info plemans. I will look into triband extenders. Cheers, Tarka
Message 3 of 3
All Replies
Guru
thats normal for extenders.
Reason they drop throughput 50% is because they have to use the same chip to go router----extender and then extender---devices.
and they can't do both at once. So while the extender is talking to the router, it can't talk to the devices.
That causes the 50% throughput reduction.
Its the whole reason for triband extenders and mesh systems. They have a dedicated backhaul that is only used for the router------extender communication. This prevents the drop.
Current setup: CAX80->Trendnet TEG-S380->GS716T-> RBK752->pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 2 of 3
Tarka
Tutor
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 231 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
