× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Remove from circle
jbolster
Follower
Remove from circle
When I chose to remove a device from circle does this mean it will be free, on its own with no controls? I have a phone I do not want to be controlled by circle. Will removing it do that?
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Remove from circle
Hi @jbolster,
Welcome to the community!
Yes, you can have a device as unmanaged (not under any profile) or set the filer level to None.
Dexter
Community Team
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Hi @jbolster,
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @jbolster,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 965 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
