× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Requesting wi-fi address on extender fails EX6110
CircuitsGleam
I just bought an extender and while it connects to my network it always fails to register a network address and defaults to my router when trying to connect. I have the extender plugged in 3 feet away from the router. 100% connection, 3 green solid lights. Does the WPS need switched off. Hmmm. No it appears that can't be switched off. Have logged into extender and after completion again it tells me "your wi-fi extender connection is up and running" while directly under this it tells me "no connection" on the networks. Will try upload screenshot. At a loss to understand. Also I've just updated to the new firmware as suggested when I logged into the extender. Any suggestions gratefully accepted, thank you
Message 1 of 5
CircuitsGleam
Re: Requesting wi-fi address on extender fails EX6110
I should have edited that screenshot--someone allow me thanks
Message 2 of 5
Guru
Did you set it up using the push button WPS option?
If so, factory reset the extender  and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Message 3 of 5
CircuitsGleam
thanks for reply. I did try the wps option but it didn't work so I used the laptop and the website thats forbidden to mention
I'll have a look at that YT vid, thanks
Message 4 of 5
CircuitsGleam
the video was one minute of setup tutorial that I had already gone thru but thank you for the reply.
It may be a Linux issue as my firestick did connect to the extended network although my laptop still refuses.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 633 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
