Reply
Router Button Won’t Light Up
CM20011
Follower
Every other button on my extender will light up except for the Router one. I set it up with the WPS button and then I tried it by going to th website and neither way worked. I also confirmed that the extender is within range of the router. Very frustrating. Does anyone have any ideas?
Model: EX6110|AC1200 Dual Band WiFi Range Extender
Message 1 of 2
Guru
Re: Router Button Won’t Light Up
What firmware is on the extender?
What router are you trying to connect to? I've read of other companies routers having issues adding extenders to them.
Does your other router have single ssid function? If so, disable it.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 368 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
