×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Router Dropping connection
Sheamatt
My router is driving me crazy. Internet works great for a day or maybe a few hours then lose connection. The wifi is on and connected but with no internet connection. Hardwire is same. Reboot the router and comes right back up. Seems to be no rhyme or reason. Just random.
AC1750 Router/R6400v2 - V 1.0.4.84
I am not using Armor either.
I honestly want to throw it out the window.
Any ideas.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 5
Guru
Re: Router Dropping connection
What modem are you connecting it to?
How long has it been going on?
when it happens, do all devices drop, just wireless, or what exactly happens?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 5
Sheamatt
Directly connecting to Verizon fios coming into house. Like a month or so. This morning woke up and no connection. Rebooted perfectly fine. Everything goes down. Wifi is connected but no internet. Direct connection no internet either.
Message 3 of 5
Guru
Fios still needs a gateway.
https://kb.netgear.com/23977/Will-my-NETGEAR-router-work-with-Verizon-FiOS
Message 4 of 5
Sheamatt
Wow. Will try later. I guess bc it worked without it, I figured no issue but I will try this setup. Thanks
Message 5 of 5
Discussion stats
  • 4 replies
  • 354 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
