×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Router EX6200 Can't connect 5G EXT
hangahliong
I am having problem connecting to my 5G EXT from my wifi range extender.
I have try to reset to factory default and change the channel from my main router but I can't connect to my 5G EXT on my EX6200, does anyone have the same problem?
I believe it has to do something with the latest firmware which is V1.0.3.74_1.1.109.
Can anyone help me with this matter or having the same matter as me but already found the solution?
Thanks
Model: EX6200|AC1200 WiFi Range Extender
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Router EX6200 Can't connect 5G EXT
Hello hangahliong
Have you made sure the security type is set to WPA2 on the 5GHz network?
DarrenM
Message 2 of 3
hangahliong
Hi Darren,
Thanks for the reply, yes my 5GHz network is using WPA2-PSK [AES], I don't know why I can't connect to that network.
Hope I can find solution.
Message 3 of 3
Discussion stats
  • 2 replies
  • 2970 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
