james2720502
Jul 20, 2023Aspirant
Router access point combination
Looking for a new router access point combination (home is Ethernet wired, so prefer access point not wireless mesh.) Router will need at least 4 ports, and will be connected to an unmanaged 17 port switch. I am looking for names and models suggestions please. Thanks
- schumakuGuru - Experienced UserRe-think your intentions.
WAN and LAN speed expectations?
Expectations on the wireless Access Points ?
Already considered PoE+ for the switches driving the APs?
Start about here https://www.netgear.com/business/wifi/access-points/ - plemansGuru - Experienced User
Why not go with a dual band mesh system if you're hardwired?
I hardwire in all my mesh systems and they work great.
the MK63, SXK30, or even the RBK350 all all dual band and pretty cheap.
