Pirouette2020
Jun 10, 2020Aspirant
Router and Satellite connection issues
Product is useless. Connection fails over and over every day. Forum has been absolutely no help.
Simply don't understand how two products from the same manufacturer and same product "family" cant simply connect and stay connected. Infuriating!
Satellite is 18 steps away from the router which is in a room with the door open, signal when connected is "weak".
They constantly lose connection. I can't walk 40' from the router without losing connection to it.
Anyone have a true solution?
Best regards,
Don
correction model is RBK50 and Satelite that came with it as a pair.
What firmware is on the router?
What firmware is on the satellite?
What modem are they connecting to?
30ft minimum is recommended between satellite and router.
What is your home made of? Certain materials block wifi such as concrete, brick, plaster lathe, adobe, foil lined insulation, or even hvac in the walls cal block the signal.
you put "connection fails over and over". This doesn't tell us much. Is it saying "connected, no internet" , does the wireless stop broadcasting, is the wireless backhaul failing, do devices simply disconnect? Do wired devices drop? Are you able to connect a wired device to the satellites and have it stay running (tests the backhaul).
Describe the problem in details, whats been tried, and everything going on. We're not there to see whats going on so its tough for us. the more you tell us, the better we can help.
- Pirouette2020Aspirant
Not to sound like the back end of a mule here... and meaning no disrespect...
But those are the same things you've asked everyone, and there's a lot of us, who have this issue.
None of it is relevant.
Issue: Satellite does not stay connect to the Orbi router. Firmware independant, clearly as discussion after discussion on the forum has shown.
Nowhere have I see someone say "Terriffic!! Great that worked. Thank you so much!".
So I've spent hours and hours and hours on this.
Flippin satellite won't stay connected to the router.
:-) Can you tell my frustration level is extremely high?
BEst reagards, and thanks- seriously.
Pirouette2020 wrote:Not to sound like the back end of a mule here... and meaning no disrespect...
And I'm not trying to be disrespectful but none of what you just said helped. It didn't answer the questions. it didn't add any info to the problem. it didn't say what you've tried. Saying you've tried for hours doesn't tell us what you've tried.
We're here trying to help others and some basic info is needed. There's no "magic fix" button.
And the reason you see issues on the forums is because its where people come with issues who are out of their support window. compare it to a hospital. You'd think everyone was sick if you looked at a hospital. Because thats where people who are sick go.
And yes, I can tell your frustration is high. But we can't help without details because we aren't there in person. And we're not paid to do this. We're simply members of the public trying to help you out for free. So I get your frustrated but bear with us. Taking it out on the people trying to help you is simply going to get us to ignore your post.
