- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router login issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router login issues
Hi,
I am trying to log into my extender but when going to mywifiext.net I am being asked to create an account (I can't log in anywhere). When I enter all the information and click on submit I am being taken back to the same page and can again only create a new account. Where do I log in?
Thanks
Andreas
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router login issues
have you tried to use another web browser when doing this or disable the pop up blocker?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Darren,
I have tried both Firefox and Safari on a Mac. I've also tried Safari on my iPhone. Always the same issue. Is there any other way to access the extender? I'd like to change the channels on it.
Thanks
Andreas
- Mark as New
- Bookmark
- Subscribe
- Permalink
The extender follows the channel the main router is on so you would need to change the channel in the router settings.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Darren,
I found out what the issue was. Initially I had set up the device as an extender but then I switched it to access point without resetting it properly. The device worked but I was only able to access the setup page once I properly reset it to factory setting and did the setup process again. Now it works.
Thanks
Andreas
