- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Setting Up Wireless Extender Model EX6200 to FiOS Router; am confused
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been looking at the instructions for setting up the EX6200 to run with my FiOS modem/router. Do I need to physically connect the router to the range extender via an ethernet cable, or do I get in there wirelessly. Please advise. Thanks.--Matthew Chao
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Setting Up Wireless Extender Model EX6200 to FiOS Router; am confused
Hello Mattchao
You can do either way but if you do it wireless I suggest setting it up in the same room as the router then after setup move it to where you need it.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, Darrenm. Thanks for the advice. If I set up the extender with the ethernet cable, do I need to run two cables, one from the router to the extender, and one to the PC or laptop? Put another way, when I hardware the router to the extender, what do I do next? Thanks.--Matt. P.S. I'm totally blind and use a talking computer to both read the pdf files and connect the wireless extender, hence, all my questions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello matt
You will want to have a Pc on the network and then go to www.mywifext.net it should ask you for a login and you want to use admin for the username and password for the password. There it should start the setup wizard and walk through the setup. If you are doing the wireless setup you will want to either connect the PC via ethernet to the extender or connect to the wifi of the extender with the default password it came with.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey Darren, once you do the set up and get the screen that says it has succesfully connected, do i then connect my xbox to my modem or the new netgear extender?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello juliojmz
You will want to connect your xbox to the stronger signal.
DarrenM
