Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Setting up Access Point in my apartment
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-23
11:39 AM
2012-08-23
11:39 AM
Hey everyone,
I hope this is an easy question to answer. I am living in an off campus apartment, but internet is provided through the school. Because of this, I don't need a modem, but rather just need to plug the ethernet cord straight to my computer and the internet works without doing anything.
I have a wireless router, a NETGEAR N300. I know I need to set up an access point in order to use wifi, but all I have been able to find so far is how to set up an access point while using another router.
So in short, I have an internet connection already that I just need to convert to wifi with my N300 router. I know access point is the way to go, but not sure how to do it.
Any help will be greatly appreciated! Thanks!
Dan
Dan
Message 1 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-23
04:41 PM
2012-08-23
04:41 PM
Re: Setting up Access Point in my apartment
First - before setting up any wireless access devices, consult your university network administrator.
Second - you can most likely use the router as a router with no modem.
Third - you can setup the router as an access point using the instructions you have - it will work. even though you only have one router.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-23
09:25 PM
2012-08-23
09:25 PM
Hello! Thank you for the reply.
I followed the directions I found which pretty much told me to change the LAN IP to 192.168.1.100 and to uncheck the box that says "Use Router as DHCP server".
Now when I try to connect to the network I get an exclamation point (on my macbook pro) on the wifi logo which tells me that there is no internet connection. This is different than before when it just connected to the network and did not tell me anything about an internet connection. The problem now is that I cannot connect to the router to access its settings, either through wifi or when then ethernet cable is connected to the router.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2012-08-24
06:34 AM
2012-08-24
06:34 AM
Normally I advise against using a router as an access point - because it's usually more of a hassle than it's worth.
Here are your possible problems.
a) For the MAC not having an internet connection ...
it may not have acquired an ip address - for which the possible reasons are ...
a1) your school only allows one MAC address per ethernet port
a2) you school requires all network devices to be registered
a3) you have the router connected via the WAN port and not the LAN port
b) For your not being able to access the router's web page
b1) the macbook pro may not have an ip address - see above
b2) the macbook pro may have an ip address in a different network range to that of the router.
Did you discuss this with the school's network administrator as I suggested?
Message 4 of 4
