×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Setting up EX 6200 As Access Point but cannot connect to internet
ChuckTaylor
I have followed the usual steps (reset router) and when I log on to the router to set it up via the Genie, it hangs on the internet connection and I get stuck there and cannot connect to the internet through the new AP setup. I have gone through the suggested connection tips but nothing has worked yet. Any tips would be appreciated.
Model: EX6200|AC1200 WiFi Range Extender
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Setting up EX 6200 As Access Point but cannot connect to internet
Hello chucktaylor
Are you trying to use the ex6200 in AP mode by connecting it to the router via ethernet or are you just trying to connect it via wireless?
DarrenM
Message 2 of 3
ChuckTaylor
Trying it via Ethernet. Followed all of the hints in the forum and figured it wasn't worth my time to keep it up. Bought a Netgear dual band wifi router and went back to using this as an extender for the new router.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2640 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
