- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Should I turn off my wifi extender when not in use?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought the wifi extender to use in the bedroom. I am only using a Roku in there and the roku signal shows poor. After setting up the extender, the signal shows good. I am very pleased! I am wondering if I should power off the extender when I am not using the tv. It is the only device that I need to use the extender for. Is there an advantage of leaving it on or powering it off?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Should I turn off my wifi extender when not in use?
The advantage of doing this is that you save a little bit of power.
The disadvantage is that it will take some time for the extender to boot and reconnect with the main router.
Although I don't like to waste power, I'd probably leave it on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you! I appreciate the response. I was more worried about the use of data than power, but will go the easy way and follow your advice!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
The extender won't carry internet data unless a client is connected to it.
If you wish, you can set up the extender to only allow the Roku (or other specific devices) to connect to it, and you can also set up an access schedule for those devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again! I will look into how to set that up!
