× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Signal Automatically Switches
NABurger
Follower
The repeater has worked flawlessly for the past year. I did not make any changes. Suddenly the repeater started to automatically switch from the 2.4g signal to the 5g signal on my iPad and iPhone. Each time I would select the 2.4g signal it would swtich back to 5g. I selected Forget this Network for the 5g signal but then the device switched to the main router signal. In the past when I booted up my iPad it automatically selected the 2.4g signal. Now I have to manually selected each time because in the settings it says "Not Connected". I Logged on the Neatgear user sight and saw my configuration all of which was correct.
Any suggestions as to how I can fix this problem?
Model: WN2500RP|Universal Dual Band WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Signal Automatically Switches
Hello NaBurger
Have you tried to use Fastlane it will only enable 2.4 or the 5ghz and give better signal maybe selecting this will keep it only on the 2.4 for you. Its in the Advanced settings of the extender.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1795 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
