Reply
Slow 5GHz connection on AC3000 tri band wifi extender
flamo
Follower
Hi, I've setup the product as a wifi extender to my nighthawk router, and on mywifiext, it shows that I have 1000 mpbs connection with strong signal strength, but when I connect to its wifi and run anything, it shows only 50mpbs max. I'm literally 5 feet away from the router, not sure what to do, please help.
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 2
Guru
Re: Slow 5GHz connection on AC3000 tri band wifi extender
The EX8000 does band steering.
Is it enabled? And if so, are you resting over the 2.4ghz or the 5ghz? (2.4ghz is a slow network)
What speeds do you get if you directly connect a pc/laptop to the extender with ethernet.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 109 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
