bluesky636's avatar
bluesky636
Smart phone not switching between EX7500 and router
My smartphone, Samsung Galaxy S10 is not switching networks as I walk through my house between the base router network and the EX7500 extended network. I have to reboot the phone, turn its wifi off and on, or do something similar to get it the switch networks.
  • plemans's avatar
    How big is your home?
    What router do you have?
    How far apart is the extender from the router?
    What router is it?
    • bluesky636's avatar
      bluesky636
      House is about 2700 square feet.
      Router is a Calix Gigacenter wifi router.
      Router and extender are at opposite ends of the house on the first floor. Depending on where you are standing, there is about a 25 to 35 dB difference in power levels between the ends. At each end, the power level is about -45 to -55 dB.
      Extender is an Ex7500.
      • plemans's avatar
        The EX7500 is a solid extender.
        but something to keep in mind with extenders and roaming.
        They shouldn't be at opposite ends. They should be in the middle of where you want coverage.
        so like this:
        Router------>extender------->devices
        and not
        router-------------------------------->extender/devices
        otherwise the extender isn't getting that great a signal as well as why would the smart devices connect to it if their connection back to the primary would give them the same speed?
        https://kb.netgear.com/25508/Where-should-I-place-my-NETGEAR-Wi-Fi-range-extender
