Reply
Sony UWABR100 not able to detect DGND3700 wilrless N signal
dipb
HI,
I have a Netgear Dual Band DGND3700 router transmitting N signal at 157 channels and 300mbps mode.
I also have a Sony EX550 Internet TV with Sony's UWABR100 USB internet dongle which is N compatible.
However, when I try to scan for available networks, the TV can only see the G signal and can connect. It cannot see the N signal at all.
Please help what needs to be done if I am missing any settings here.
Message 1 of 5
jmizoguchi
Virtuoso
Re: Sony UWABR100 not able to detect DGND3700 wilrless N signal
DGND3700 is NOT access points.. it is WIRELESS/WIRED ROUTER
Belongs to http://forum1.netgear.com/forumdisplay.php?f=33
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 5
dipb
Sorry.. I did not understand what you are trying to say..
DGND3700 is a wirless router. But it does act as an access point.
An access point is through which you access.
The question I have asked here is that DGND3700 is transmitting at both 2.4GHz and 5GHz (n network). However, Sony dongle can only see the 2.4GHz signal. Sony claims it is supports a/b/g/n network.. then why I am not able to see the n network or how can I see ?? ?
If you can solve the problem, pls reply back.
Message 3 of 5
jmizoguchi
Virtuoso
doesn't matter.
posted on wrong area
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 5
dipb
jmizoguchi wrote:
doesn't matter.
June.. moved. now answer only if you know the solution.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 8334 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
