× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Trouble connecting WiFi extender to devices
MitchP95
Hello - I did a factory reset and followed the set-up wizard. I hard wired my laptop to the extender and the set-up was successful -- I was able to disconnect the ethernet cable was able to use the _EXT network.
However, when I try to connect my iPhone oriPad - no luck. They both see the new _EXT network but when I try to connect and touch the new network name (like you'd connect to any WiFi network), it says, "no internet connection" and there's an exclamation point ontop of the WiFi icon.
Any suggestions?
Model: WN2000RPTv3|WiFi Range Extender
Message 1 of 13
DarrenM
Sr. NETGEAR Moderator
Re: Trouble connecting WiFi extender to devices
Hello MitchP95
Are you using a form of WPA2 security?
DarrenM
Message 2 of 13
MitchP95
Thanks, DarrenM. I just double checked using 192.168.1.1.) and yes, I'm using WPA2.
Message 3 of 13
DarrenM
Hello Mitchp95
Are just you apple devices not working on the extender and all other devices work? Have you told the apple devices to forget the networks?
DarrenM
Message 4 of 13
MitchP95
Hi DarrenM -
I tried forgetting the new router and reapplying to it with Apple devices, but didn't work. So I just did another factory reset on the router and set it up through the wizard on my laptop. I'm connected right now through the router _EXT typing this.
And as suggested, I tried to connect with another (non-Mac) laptop and no luck. When I hover over the wifi icon in the toolbar, it says, "Unidentified Network, No Internet Access." I'm reading this as the same problem with the Apple devices.
Message 5 of 13
DarrenM
Hello MitchP95
Have you tried to add the mac address to the allow list of the router?
DarrenM
Message 6 of 13
MitchP95
I have not! Can you point me to where I can read up on how to do that?
Message 7 of 13
DarrenM
Hello MitchP95
What  model router do you have?
DarrenM
Message 8 of 13
MitchP95
WN2000RPTv3
Thanks!
Message 9 of 13
DarrenM
Not the extender the model of your router.
DarrenM
Message 10 of 13
MitchP95
Ah, sorry. I'll send that in a few hours.
That said, does it matter that the Mac devices work perfectly well and auto-connect to the router?
Message 11 of 13
MitchP95
Hi DarrenM,
It's the fios 61100 router.
Message 12 of 13
DarrenM
Hello MitchP95
I found it on page 50 of the user manual I linked below you can add the mac address of the extender to the router.
http://www.verizon.com/about/sites/default/files/fios-qgr-userguide140925.pdf
DarrenM
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 3106 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
