× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Trubble after upgrade WN3000RPv3
Henrik2018
My wifi extender stop working after upgrade. I tried to reset but it does not work. The green led blink. No other lights. What kan I do ?
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 3
schumaku
Guru
Re: Trubble after upgrade WN3000RPv3
The green LED .... please refer to the WN3000RPv3 User Manual for the LED information on p.6. Talking about the Power LED probably?
You have to figure out if the extender does answer to ping on the default IP 192.168.1.250 (use the RJ45 LAN connector) - for this you need a computer in the same subnet, ensure .250 is not used by any other device on your network. This might allow to tftp to push the potentially broken firmware. Process is similar to this -> https://kb.netgear.com/19841/Reinstall-the-firmware-on-a-router-without-the-setup-CD-recovery-tool
Message 2 of 3
Henrik2018
I ping 192.168.1.250 The ansver was:  Reply from 192.168.1.170 Destination host unreachable. I run tftp2.exe, in the field "server" I wrote 192.168.1.170, the field "password" I left emty. I got the error "unable to get response from the server". Is my netgear wn3000rpv3 ready for the trash bin ?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 630 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
