× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Two extenders
Oaktree27
Follower
Two extenders
Can i hook up two extenders? and how do I set it up?
Model: EX6100|AC750 WiFi Range Extender
Message 1 of 2
Guru
Re: Two extenders
You can.  The normal way is to connect both extenders to your router.  It is also possible to daisy-chain them, but that won't work as well.
As far as the logistics go, one approach is to set up the first, then turn it off and set up the second.  Then turn on the first one.  Use different network names for the two extenders.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 482 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
