- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
URGENT HELP PLEASE -NETGEAR ROUTER NOT FOUND OR NOT SUPPORTED
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear All,
i have been trying to log in netgear genie but it keeps showing me "NETGEAR ROUTER NOT FOUND OR NOT SUPPORTED".
I tried to reset the router; i to put original firmware through "Tomato" IP 192.168.1.1 "tomato-R8000-1.28.AT-ARM7-3.5-140-initial-64K"; upgrade "R8000-V1.0.3.4_1.1.2" but whatever i did was not helpful.
can you help me please?
I also tried to do the router set up through the netgear genie app (android). I caught QR code and started the configuration; i restarted my modem and i cabled it with Nighthawk, then i restarted. I also changed my modem IP address as it was same as Nighthawk router's one but it keeps not working
My goal is simply to use my router as a wifi extender. My modem is Tim Hub (Telecom).
Look forward to receiving your feedback.
Best regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: URGENT HELP PLEASE -NETGEAR ROUTER NOT FOUND OR NOT SUPPORTED
so you had tomato on it and tried to get back to the original and you can't?
Recommendation? post this on the tomato forum. They're the experts on how to remove the software that was installed on it and the issues it causes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
tomato and netgear genie don't work together.
If when you go to 192.168.1.1 you are still accessing tomato, then its still installed and genie won't work. Its a 3rd party firmware unsupported by netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you don't need genie and its working fine, leave it.
If you want genie then followup with the tomato forum for removing tomato and reinstalling the original firmware.
We don't help with 3rd party firmware, you need to do that on the appropriate forum
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks in advance for your reply
- Mark as New
- Bookmark
- Subscribe
- Permalink
You don't have netgear firmware running on the router. Its like calling micrsoft for a computer that you installed linux on.
Please go to the tomato forums for assistance.
