× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Unable to Connect a Second Extender
LDLTH
I have been using the AC750/EX3700 WiFi Range Extender without any issues for a year. However, after buying a second one, I can't get it to show up since the WPS is not staying lit. It flashes when it's trying to connect to the router but then turns off. What do I have to do to get my router to recognize the second one.
I do not have a Nighthawk Mesh although that was the only choice I had to pick.
Model: EX3700|AC750 WiFi Range Extender Essentials Edition
Message 1 of 5
Accepted Solutions
LDLTH
Re: Unable to Connect a Second Extender
Thanks for your help and patience. I finally got it to recognize the additional extender. First, I had to unplug the first one. Second, I plugged the new one in and reset it. Finally, I was about to see and connect to the NETGEAR_EXT (SSID) WIFI network. After I did all of those things, then I was able to get to set up the new extender. Of course, make sure you give it a name that's different than the first extender.
If Netgear would only have posted this second piece of support, a lot of the frustration would have been eliminated.
Message 5 of 5
All Replies
Guru
try setting it up using the installation assistant and not wps. There's a video on the support site for the ex3700
https://www.netgear.com/support/product/ex3700
Message 2 of 5
LDLTH
Thanks for responding. Since I have an existing extender, do I have to turn existing one off to get the second one to be recognized? I tried to connect before with the Web Browser Setup but I had problems.
Message 3 of 5
Guru
try shutting off the one that is already setup.
Message 4 of 5
LDLTH
Message 5 of 5
Discussion stats
  • 4 replies
  • 1102 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
