- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to access ex6150v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was trying to update firmware and it locked up and now I cannot gain access to it no matter what I do. mywifiext website doesnt work - wired/wireless doesnt work. Reset it multiple times. Any ideas??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to access ex6150v2
What are the leds on it doing? (all of them, color/blinking/solid/etc)
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- Mark as New
- Bookmark
- Subscribe
- Permalink
only the power button is on and green. Thx for info - Im on windows and will give it a shot and let you know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
tftp didnt work and instructions for nmprflash seem to be for a router and not extender so not sure how to proceed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i get to the advertising server on nmrpflash but nothing after that. Do I have to set compter to static ip first?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What error do you get on the nmrpflash setup? theres a faq on their site.
also, is it within warranty?
you could open an RMA cast if it is.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I get the advertising NMRP server and then just disconnects. hard to follow directions on site since most are for routers and not extenders. no longer under warranty
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you can't get tftp/nmrpflash to work, then your device might be bricked. You can try forcing firmware to it through a serial port but that'd require buying parts to do so and finding a guide. not for the faint of heart
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok, sounds like throw away time. thx for the guidance
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
