- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unable to connect
Is the a phone # somewhere to call! This is painful!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to connect
What modem and router did you replace with? Firmware on them?
Firmware on extender?
Whenever you replace a router and are using your same extender, its good to factory reset the device (extender that is). This removes old settings and should make redoing it easier.
You say the green light is flashing and then goes off. Which leds? There are 4 of them. Describe what each is doing.
here's the support site with manuals, firmware, and installation guide.
https://www.netgear.com/support/product/EX6110
You do have the option of contacting support. There is 90 days of free support. After that you have to pay for it. If you'd like to do that route, go to the top and click on mynetgear, after that register an account and your device. From there you can contact support.
