× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Unable to view connected devices on Nighthawk EX770
PMC64
Tutor
Dear all
Whenever I click on Connected Devices it says please wait and times out and nothing is displayed. The Nighthawk is configured correctly with the latest firmware. However I am unable to view connected devices. Has anyone encountered this before?
TIA
Pierre
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 1 of 8
Guru
Re: Unable to view connected devices on Nighthawk EX770
A couple things you can try.
1. not sure if you logged in through the mywifie . ext or using its ip address. Try the ip address if you didn't
2. try a different browser. I'd recommend firefox. but try a couple
3. did you reboot it?
4. Have you tried factory resetting and reinstalling it?
What firmware version are you on?
Message 2 of 8
PMC64
Tutor
Hi
Thanks for your reply.
The Nighthawk is on FW V1.0.0.210
I am logging in via the IP of the Firehawk.
I am using Google Chrome. Tried Edge. Same result.
I did not reboot it. Neither did I do a factory reset because it was deployed a few weeks ago.
Thanks
Message 3 of 8
PMC64
Tutor
I rebooted the Nighthawk and I am now able to view the connected devices. However this seems to be happening quite often. Does that mean that I have to stay rebooting the Nighthawk every time this happens?
Message 4 of 8
Guru
If it continues to happen, I'd roll the firmware back to the .206 version, factory reset, and reinstall. disable the auto updates until there's a new version. I've seen issues on the .210 version
Message 5 of 8
PMC64
Tutor
How do I roll back the firmware update? By doing a factory reset and installing the .206 update? I've received complaints that users are unable to access the Internet. It is intermittent.
TIA
Pierre
Message 6 of 8
Guru
You download the firmware version you want, then unzip it.
Then just follow the manual firmware update process and use the firmware you downloaded.
https://kb.netgear.com/000061572/How-do-I-manually-update-the-firmware-on-my-NETGEAR-WiFi-Extender
https://www.netgear.com/support/product/ex7700
Message 7 of 8
PMC64
Tutor
The issue has cropped up again therefore I will roll back to the .206 fw version.
TIA
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 617 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
