×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Universal WiFi Range Extender WN2000RPTv2 Working but cannot access to change password
Chesterfield916
Initiate
I have a range extender which is successfully connected to my router via wifi using wps.
I am presently connected to the extender with a cable and have access to a network.
What I can't do is access the extender via wifi.
I have tried a factory reset and it's not working. When I try to connect I can't get the password right.
How do I connect from the PC via cable and change the password?
Message 1 of 3
Accepted Solutions
Guru
Re: Universal WiFi Range Extender WN2000RPTv2 Working but cannot access to change password
What happens when you factory reset?
After you reset, follow the installation assistant and NOT wps.
https://www.youtube.com/watch?v=yJVklshxBMk
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
All Replies
Guru
Message 2 of 3
Chesterfield916
Initiate
Huge thanks. I've tried the factory reset but each time WPS came on and connected.
Decided to try one last time but powered off router and extender first, can't believe I haven't reset the router.
Powered on router.
Powered on extended.
Accessed from laptop selected extender network and it took me through the set up and is now working!
Many thanks ... Wimbledon womens final has now finished though! This is what I was wanting to watch when I couldn't connect!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 268 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
