mklein3273's avatar
mklein3273
Follower
Feb 04, 2019
Username "admin" does NOT work. I know my password, any help appreciated
Trying to set up 2700 extender Have it almost completed until I click on the NETGEAR_EXT and it ask for a WPA2 password. I use the password on the router/modem That does not accept.
Any suggestions
THe solid green light that says the extender is working is not going on because I need the password
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi mklein3273 - Hard reset the extender and join the NETGEAR_EXT wifi network.  After you connect to it, browse to www.mywifiext.net and log in using the default credentials (Username: admin - Password: password). Then follow the setup instructions.
    ~Christian
