× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Using N300 Wireless extender ethernet port for a desktop
bradwjames
Follower
Hi
There is an ethernet port on the bottom of the extender. Can I use it internet access by plugging the ethernet cable from a desktop computer into it? I tried but the computer does not appear to see the internet connction.
Model: EX2700|N300 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Using N300 Wireless extender ethernet port for a desktop
Hello bradwjames
yes you should be able to use this port if the extender is connect via wireless to your main router.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4868 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
