- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Using extender blocks previous range of access from router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since installing this range extender, although that works well, I can no longer access wifi in areas that the original router used to cover.
In some areas that the router covered, my mobile can't pick up the original router wifi signal but can pick up the extension - which is weird since the router is much nearer than the extension. This particularly happens with my mobile phone.
I'm obviously only put out by the areas where I can no longer connect to any home network.
Does the extender somehow drain the signal in its direction?
Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Using extender blocks previous range of access from router
Hello BBB00
Have you tried to change the wireless channel on the main router to see if you can get better signal in those areas.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Many thanks for your response. I'm a newbie and have been looking in to how to change the channels but can't see how. Have got to my page (which is with/through the Orange router interface) and can't see anything that shows the extender on it. I've gone through Netgear genie and although I deselect extending the 5Ghz network, to try to keep that separate for the original line, the next page includes it again with no possibility to deselect. Not sure if that changes anything. Any suggestions gratefully received.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello BBB00
You just need to change the channels on the Orange router.
DarrenM
