×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Using two Wifi Range Extenders in one house
Treesurfer78
Follower
Hi all
Hoping for a little bit of help here. I have been using a Netgear Wifi Range Extender to boost the signal to the deadspot in my house for a number of years now without problem. I recently bought a second extender to boost the wifi signal to my outside garage. The new extender connects to my Wifi, but not via WPS (The WPS light is unlit on the new unit, but is lit on the original unit). I know very little about wifi and associated systems, so if someone could advise me if using the second wifi extender without WPS is OK, or if I can connect it via WPS, or if I should be doing something else would be very much appreciated.
Thanks in advance and apologies if this topic has been asked and answered elsewhere already.
Cheers.
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 1 of 2
Guru
Re: Using two Wifi Range Extenders in one house
You don't have to set it up using wps. You can set it up using the installation assistant.
How to Setup your WiFi Range Extender with NETGEAR Installation Assistant - YouTube
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 215 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
