- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Virgin Media Hub 2ac and Netgear EX2700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi folks,
I'm pretty new to all of this, so I'm looking for some guideance around connecting my Netgear EX2700 to my new Virgin Hub 2ac (just moved home)
The EX2700 has been a joy to work with these past few years, until it was introduced to Virgin 😉
Now I cant do anything with it, and it keeps asking for a WPA2 password - which I discovered and used but to no avail...
Could anyone guide me towards easy to follow information, and set up proceedures?
Thank you
Cenihk
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Cenihk
Since this is a new router you will want to reset the Ex2700 because it is trying to use old settings what you want to do is hold the reset button pin hole for 10 seconds this will do a factory reset then you should be able to go through the setup and connect it to the new router.
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Cenihk
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Virgin Media Hub 2ac and Netgear EX2700
Thank you for your support, it is now working well... 😉
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
